CSV-1537 data + Charging through USB-C Port?
Updated on 29-11-2017 in USB Type C
1 on 28-11-2017
Hy Guys,
I was wondering if the USB-C dock CSV-1537 with DP1.2, USB-C and USB 3.0 slots will support data streaming via the USB-C port on the dock or if that slot is for charging only?
So would it be possible to put in a USB-Stick in the USB-A and the USB-C slot and for example transfer data from one to another?
Thanks and cheers
Woiz
0 on 29-11-2017
Hi Woiz,
That USB C Port (nr 2 on the picture) is for charging only, it does not carry data.
