CAC-1070 is flicker and unaligned randomly
Updated on 11-07-2016 in Adapters and Cables
5 on 23-06-2016
I bought CAC-1170 from Amazon.com. My machine specification is:
– Lenovo ThinkStation P900, Xeon E5-1603 V3, 16 GB RAM
– Video card: Zotac GTX-750 2GB
– Monitor: LG UF770T UHD TV
CAC-1170 can convert DisplayPort 1.2 signal to HDMI flawlessly. I set the resolution using Nvidia Control Panel as 3840*2160p 60Hz 4:4:4. However, the card somtimes display some flicker & noise randomly. Sometimes, the display is unaligned with the screen position. This annoys my using the product.
How can I fix this problem?
0 on 27-06-2016
Hi, I’ve got similar issues.
Specs:
– Acer Predator 17 notebook with GTX980M gpu
– TV: LG 49UB820V
Sometimes display is unaligned (or some colors only), it shakes strangely or flickers. I’ve used two separate HDMI cables (also one of them was completly new, just out of the box).
0 on 10-07-2016
Same here. Crossfire AMD Fury, LG 49ub8500
1 on 10-07-2016
Also, I had a similar problem when I was using a AMD 280X but it wasn’t as common, there was no popping sound and if I turned the TV off and on again it would fix it. With the Fury’s I have to restart my PC to correct it.
on 11-07-2016
firmware emailed
0 on 11-07-2016
My CAC-1070 has label as REV: A2-00, FW: V7.2.3, 1615.
I got the new firmware from support@club-3d.com and now the problem is resolved. Please contact them for the new firmware.
