Club 3-D CAC-1130: Apple Cinema HD 30″ to 2016 Macbook Pro connection problem
Updated on 04-08-2022 in Adapters and Cables
5 on 29-01-2022
I picked up the mini-display port to dual link DVI adapter to connect my 30″ Apple Cinema HD to my 2016 MacBook Pro retina. They connect no problem and the display turns on and looks fine. But only for a few seconds. Then it goes black and stays black. The only solution is to disconnect and reconnect. The display turns on again for a few seconds before going back to black. Lather, rinse, repeat. Does anyone have a solution for this? Thanks for the help
0 on 31-01-2022
Check with support@club-3d.com
Might be a firmware issue on the adapter.
0 on 27-07-2022
Hi Billy, I have the same issue. 30″ cinema display with a circa 2019 macbook pro. Turns on for a few seconds then turns off. How did you go with resolving the issue?
1 on 27-07-2022
In looking through the adapter, it seems there are 2 versions. HDCP on and HDCP off. This could be it!
on 04-08-2022
You’ll need the “OFF” version. If you got the “ON” version contact support@club-3d.com for a firmware update.
0 on 27-07-2022
Hi Kuno. When I posted this, I wasn’t aware of the HDCP issue. When I contacted the company, they offered to provide the version that works. I got it in the mail a few days later and its been working like a charm ever since. It was fantastic customer service. Good luck.
