Club 3d docking station not recognizing monitor
Updated on 24-10-2025 in Docking Station
10 on 14-03-2025
Hello.
New laptop, Windows 11 and new docking station.  The hdmi cable works while being plugged into the laptop.
I want to plug the hdmi cable into the docking station and have it handle my monitor.  Any assistance is appreciated.  I have followed the trouble shooting regarding the docking station.
0 on 14-03-2025
Which dock, laptop, display? Does the dock do anything? USB peripherals work? Network works?
0 on 16-03-2025
I am new to using the Club 3d docking station.  I previously had a Dell docking station.  New laptop as well, Acer Nitro V15.  My cooling fan is plugged into the docking station.  My Acer monitor is the only item not working.
3 on 16-03-2025
List the model numbers of your docking station, laptop, and display.
There are many Acer Nitro V15 models.
https://www.acer.com/ca-en/laptops/nitro/nitro-v-15
Club-3D has multiple docks.
https://www.club-3d.com/en/cat/1607/universal_docking/
Different displays may have different HDMI requirements.
on 02-04-2025
Hello Joe:
USB Gen1 Type-C Triple Display Dynamic PD Charging Dock with 65 Watt PS
Nitro V15, Intel core i5, nvidia Geoforce NTX, DTSX Ultra, Nitro Sense, DDR5, Wi-Fi6, Thunderbolt, HDMI2.1
on 02-04-2025
Joe:
Acer Display ED27OR
1 on 02-04-2025
Is it the Club 3D CSV-1564W65 USB Gen1 Type-C Triple Display Dynamic PD Charging Dock ?
The CSV-1564W65 appears to use a DisplayPort 1.2 MST hub limited to two lanes of HBR2. The total pixel clock for all displays must be less than 360 MHz (assuming RGB 8bpc).
You are connecting only one HDMI display so it should be able to handle 4K30 (297 MHz HDMI) or 1440p60 or 1080p120.
The CSV-1564W65 must be connected using a USB-C 5 Gbps or 10 Gbps or 20 Gbps or passive Thunderbolt 3 or 4 or 5 cable to a USB-C or Thunderbolt or USB4 port that supports USB-C DisplayPort Alt Mode.
A charging cable is not sufficient. You should be able to connect USB devices up to 5 Gbps to the dock. If that’s true, then the cable is ok.
Is your Acer model number this: Acer Nitro V 15 ANV15-51-50Z1 | NH.QNAAA.003 with RTX™ 2050? It appears that the only USB-C DisplayPort Alt Mode capable port is the Thunderbolt 4 port.
Do you have any USB-C to DisplayPort or HDMI adapters or cables that can be used to test the video output of the Thunderbolt port?
on 06-04-2025
Hello Joe:
My laptop is an Acer V15-51.
0 on 19-04-2025
On my docking station, there is only one port for an HDMI Cable.
