I’ve got a problem with this hub, which from what I can tell from the production web page should support using a simple passive DP-to-DVI adapter when using screens that does not support DP.
The graphics card has 1DP1.2+1DVI
Currently we have a DVI screen connected to the graphics card and the HUB connected on the DP of the graphics card. Then we have a DP screen connected on the HUB and one DVI screen connected on the HUB via a DP-to-DVI adapter that can with the computer (a DELL one).
We’re seeing some strange stuff. Connecting the screens doesn’t immediately give you image on the DVI screen.
Checking the screen setup in Windows, the screen is there and it’s possible to drag windows onto it, but the screen is black.
It takes 5-10-15 MINUTES for the image to appear and once the image appears, the image quality is very poor, can also be partially “off screen” and has a static kind of flickering.
We bought two HUBs and have tried them both with same result.
We’ve tried switching the one DVI screen connected to the HUB with a DP one, which works perfectly.
We’ve tried multiple DP-to-DVI adapters to rule out they don’t work (they work fine when connected on the graphics card as well).
This is supposed to work no?
Does the passive Club3D DP-to-DVI-adapter do something differently from a regular DP-to-DVI-adapter?
Ideas?
