CSV-1568 loses network connection
Updated on 27-04-2023 in Docking Station
3 on 08-03-2023
Hello,
My Laptop (Asus ROG Flow x13) connectet to the CSV-1568 loses the Network connection randomly.
I allready installed the latest network drivers for the CSV-1568 from the Club 3D homepage.
The RJ45 port on the dockingstation stays active (LED indicators are flashing/on).
A restart of the dockingstation solves the problem until it apears again after hours, or days.
Anyone with the same problem and/or a solution for it?
0 on 08-03-2023
Check your usb settings, make sure Windows is not allowed to turn of the USB to save power.
0 on 09-03-2023
Thanks,
It seems as if that solved the problem.
