CSV-1568 problems with Probook 460 and thinkbook 16 (Both Core5 Ultra)
Updated on 02-02-2026 in Docking Station
17 on 19-03-2025
We are experiensing a lot of problems with the CSV-1568 Dock. We sold about 40 pieces together with Probook 460 (ultra5) and thinkbook 16 (ultre5). Both notebooks (different production batches) experience the same problem:
when starting the notebook with dock including power adapter in the dock: usb and network are not working, and the notebook reacts slower.
when starting the notebook witt dock EXCLUDING power adapter in the dock: All works fine. Poweradapter can be added…. no problems
We cannot ask all customers to detach and attach the adapter at every powercycle.
Does anyone experience the same problem?
Kind regards, Frank
5 on 25-03-2025
Sometimes there are powersaving settings enabled on USB ports from the source (laptops). Could you check and disable those?
on 25-03-2025
The problem is already there at startup of the notebook.
These settings had allready been changed. Strange thing is that the dock functions perfectly without the power adapter connected at startup. Connecting the power adapter afterwards also functions well. So we think there is a problem with the Dock in combination with notebooks havin a net Core Ultra Processor. We also mentioned this to Wiktor of Club-3D.
The following things are connected to the dock:
2x 24″ fhd screens / logitech unify adapter / network cable
on 25-03-2025
Ok that’s clear, I don’t know what has been discussed with Wiktor, I’m just a passerby 🙂
When the power is connected, is there anything connected to the lower USB-C too (Pic A)?  If yes, disconnect that. Is the host connected as Pic B?
Pic A:
Pic B:
on 25-03-2025
initially we used the power supply which was send with the dock.
Host is connected to the “To Host” connector (pic b)
We also tried a usb-c powersupply which we connected to the usb-c connector on pic A
Both same result
on 25-03-2025
Is there any other power source connected to the notebook?
on 25-03-2025
no
2 on 28-03-2025
We are actively working on this issue. Based on our findings, newer HP laptops use a different voltage control method on the USB-C communication line compared to the rest of the industry. This is causing the chipset in our docking station to fail to initialize correctly.
We have already contacted the chipset manufacturer, who has ordered HP laptops for testing. They are currently working on a firmware update that should resolve the issue without requiring any changes from HP. We expect to receive an update on this topic the next week.
We will keep you informed as soon as we receive further details. Please let us know if there are any additional concerns in the meantime.
Best regards,
Wiktor
Club3D
on 02-04-2025
I’ve subscribed to this thread.  We have many Club3D dock across multiple clients using newer HP laptops with second (and third) screen flickering and disconnect issues.  The rate of frequency increased tenfold when we switched them from the older HP branded docks to the Club3D a couple years ago.  Hoping this finally being resolved means a firmware is made available to all of us, and soon.
on 10-04-2025
We also experience these problems….. next to the already mentioned issue…..
Customers are getting really pissed………
3 on 25-04-2025
We have a new firmware that solves this problem, please contact support if you are still experiencing problems.
on 06-05-2025
From Wiktor
The only contact for club3d support is their RMA email address, which I emailed earlier.  Is this the best method?  Can this not be provided via a link on the club3d website?
on 07-05-2025
on 12-05-2025
Unfortunately the dock firmware Wiktor provided did not help with screen disconnects or flickering with the two HP EliteBook 860 16 inch G9 Notebook PC laptops we tested.  I’m in direct contact with them through email, just figure I’d mention it’s not working for all.
2 on 06-05-2025
We installed the new firmware….. So far so good
No more unstable dock and no more flickering screens….
Please put the firmware on de site as a download.
Kind regards Frank
on 13-05-2025
Wiktor, as you see in this customer’s reply there’s another example of ‘flickering screens’.  [Wiktor pretended privately that our flickering screen issue was unusual or unique]
This reply is one reason I was hoping the firmware would help address our intermittent display issues.
on 16-05-2025
We spoke to other people who had experienced this problem. The pattern was always the same: video up, data down. There was no screen flickering.
Flaarhuis, could you confirm whether your problems included screen flickering?
