• All
  • Members Lounge
  • USB Type C
  • Docking Station
  • MST Hub
  • USB Graphics
  • Adapters and Cables
  • Graphics cards
    • R9 Series
      • R9 Fury Series
      • R9 390 Series
      • R9 380 Series
      • R9 290 Series
      • R9 280 Series
      • R9 270 Series
    • R7 Series
      • R7 300 Series
      • R7 260 Series
    • R5 Series
    • Others
    • HD 7000 Series
  • Technology
  • Market Place
    • Hot Deals
    • For Sale or Trade
  • Warranty questions
  • Never Settle Campaign
  • News
Club 3D Insights
  • Unfollow
  • Follow
  • Profile
  • Logout
CSV-1580 Thunderbolt 4 Portable 5-in-1 Hub: power consumption and heating
Updated on 23-05-2023 in Docking Station.
  • Close
  • Delete
4 0 on 17-02-2022
AW3dclub
Generally Thunderbolt 4 docks/hubs are well known to heat and to
have themselves quite an important consumption of power for/of their
own use.
What about these issues for products from Club 3D?
How much power does the CSV-1580 TB4 hub consume for its own use in idle no devices/nothing connected only connected to the host?
What is the temperature it attains this way (in idle) at/on the outer surface? Does it need a special cooling? Is there a fan inside?
Best regards
Save Cancel
0 0 on 18-02-2022
joevt
All Thunderbolt 4 hubs/docks use a similar amount of power since they all use the same Goshen Ridge Thunderbolt 4 controller. I suppose a dock may use slightly more power since they have additional USB hubs and devices inside.
All Thunderbolt 4 hubs/docks do not require special cooling or fans. At least I haven’t seen any that had fans or vents for a fan. I have an HP Thunderbolt Dock G2 that has a fan but I didn’t know it had a fan until I took it apart.
The power requirements are unclear. It comes with a 100W power supply but says it can supply 60W for host and uses 85W for host and hub. So what about the remaining 15W?
The type-A port can provide up to 900mA @ 5V = 4.5 W. I guess the type-C ports can provide up to 15W. Power used by these ports beyond a certain point must reduce the power that can be provided to the host.
Save Cancel
Reply Cancel
1 0 on 11-06-2022
gimoh
This hub has serious power management issues. I’m trying to have an answer from CLUB3D but nobody replies to my mail and post here in the forum. THIS HUB MAKE THE HOST VERY HOT because I’m afraid it has no power management at all and keeps charging the battery even if it is fully loaded. I made all tests with exact same setup with and without the hub. The difference in temperatures of the host is over 20°. That’s could be an issue with the item I received OR a design issue, But I can’t get any specific Info about it. That’s a shame. Amazon accepted the return for a full refund. I’ll go with a more trusted brand and a very similar price. CLUB3D should give more attention to customer care, after-sales assistance, and technical information.
Save Cancel
0
Dana
@gimoh which other brand did you buy in the end, and would you recommend it?  Thanks
Reply Cancel
Login to Reply
Reply Cancel
  • All Posts
  • Following Posts
  • Blog
Copyright 2025 Club 3D B.V.
