ISSUE: Can only get the touchscreen capability of one of two external monitors working when using your MST Hub! (display to both works).
I have 2 Planar CT2785 touchscreen monitors connecting to your CSV5300A MST that is then connecting to my top-of-the-line Microsoft Surface Pro 3.
The cabling is all Displayport 1.2.
Each of the two monitors has two connections: one displayport to your hub, the other USB to the Surface Pro 3 for the touchscreen capability.
All three monitors (including the Surface Pro 3 screen) are displaying properly but the touchscreen capability is only available on the Surface Pro 3 and on one of the two external Planar monitors (whichever one of the external monitors that I specify on the computer as the Main Display).
How can I activate the touchscreen capability to work on both of the external monitors at the same time?
Is this an issue with your MST Hub? Can you pls help me resolve it. Otherwise, I cannot make use of the touchscreen capability of the other screen!
Thank you in advance for your prompt assistance with this matter. Hope you can help me resolve it.
