Hi, I want to connect an LG 38GN950 monitor (https://www.lg.com/us/monitors/lg-38gn950-b-gaming-monitor) to a Dell Latitude 5310 laptop (https://www.dell.com/support/manuals/en-us/latitude-13-5310-2-in-1-laptop/lati_5310_2_in_1_setupspecs/ports-and-connectors?guid=guid-bf77d3d3-74dc-46f0-9288-a41e578b290e). The monitor’s max resolution is 3840×1600@144. The laptop has an HDMI 1.4 port, but according to specs also supports DisplayPort 1.2 over USB Type-C in Alt Mode. The USB socket has the flash icon (https://www.club-3d.com/en/technology/15/usb_c_over_alt_mode/) so Alt Mode should be supported.
As HDMI 1.4 only supports 4K at 30Hz (https://en.wikipedia.org/wiki/HDMI#Version_1.4) I only get 30Hz when using the latop’s native HDMI port. But of course I would like to get as high a refresh rate as possible. So I thought using DisplayPort 1.2 over USB Type-C in Alt Mode should manage up to 60Hz even in 3840×1600 (https://en.wikipedia.org/wiki/DisplayPort#1.2).
I got this (probably low quality) LogiLink adapter, which claims to support 4K@60: https://www.reichelt.com/de/en/usb-3-0-adapter-usb-c-hdmi-usb-a-usb-c-4k-60hz-aluminum-logilink-ua0390-p337093.html but I only got 30Hz for every resolution above 1080p on the Latitude laptop. I then tried it on an Dell Precision 7760 (https://www.dell.com/support/manuals/en-us/precision-17-7760-laptop/precision_7760_specs/external-ports?guid=guid-a1a8875e-b8bc-4c43-9e7b-97f30705ba6) where I got up to 60Hz. So I am wondering what prevented 60Hz on the Latitude 5310 and if another adapter like the Club 3D CSV-1534 (https://www.club-3d.com/en/detail/2386/usb_type_c_to_hdmit_2.0_usb_2.0_usb_type_c_charging_mini_dock/) would enable it?
Furthermore, this LogiLink adapter had a problem on both laptops: namely that it only seemed to support 16:9 resolutions. The LG 38GN950 always had black stripes on both sides for every resolution. For 21:9 resolutions there were even black stripes on the top and botton, too. I hope this is nothing the CSV-1534 would have.
So how would I get the maximum refresh rate (at least 60Hz) at 3840×1600 out of the Latitude? Should the CSV-1534 be able to do it or is there a limitation with the laptop preventing it? Any thoughts? Thanks!
