Oculus Rift and DisplayPort to 3xHDMI adapter
Updated on 27-10-2016 in Adapters and Cables
2 on 24-10-2016
I purchased a DisplayPort to 3x HDMI adapter to connect my Oculus Rift to a Windows10 computer with M6000 graphics cards.  I have a simple DisplayPort to HDMI cable converter, which allows the Rift’s software to detect the Rift, but not send a signal to the Rift and someone recommended the Club3D product as a solution.  However, when I plug the Rift into the Club3D adapter, the software cannot detect that the Rift is connected to the computer.  Any suggestion for possible solutions?
1 on 27-10-2016
You mean you have a CSV-5300H Displayport MST HUB ?
If it is just to connect your Oculus rift, i would suggest to use a CAC-1070 = Displayport to HDMI2.0 Active adapter that can also do 120Hz up to 1080 p
What resolution is your Oculus Rift running on ?
on 27-10-2016
Thanks for the suggestion!  It turns out the problem I outlined above seems to be a defective CSV-5300H because I cannot get it to connect to a normal display.
