Hey.
I just received my CSV2302 but I am having problem making it work. I expect something is wrong with it and wanted to hear here, before taking contact to the dealer and returning it as an RMA.
I have installed the latest Displaylink driver from Club 3Ds webpage. The installation says 8.2.1491.0. Afterwards I plug the CSV-2302 into the USB 3.0 port (without the DisplayPort cable connected) and the computer registers the device in the device manager in Windows as it is supposed to. When I connect the screen via the Displayport, the the CSV-2302 disappears from the device manager after a couple of seconds. It can be seen on the screen, that it registers something has been plugged in, but goes into power saving mode right away instead of saying no signal.
Furthermore, the CSV-2302 is generating a lot of heat. After just a couple of minutes in the USB port, I can measure surface temperatures with an IR thermometer of more than 50 degrees Celsius on both sides of the device. It is also making a buzzing/bibbing sound, as over power supplies sometimes does. This is regardless of whether the screen is plugged in or not. Because of this, I expect something to be wrong with the device or can someone confirm this is normal operation and thereafter guide me to a solution of my problem?
I have reinstalled the driver multiple times.
Setup:
Lenovo Y500 with gt650m, i5-3230m 8GB RAM
Dell U2415 screen
Windows 10 Home version 1607 build 14393.1066
Hope someone can help, or maybe confirm that something could be wrong with the CSV-2302?
Regards
Jesper
