• All
  • Members Lounge
  • USB Type C
  • Docking Station
  • MST Hub
  • USB Graphics
  • Adapters and Cables
  • Graphics cards
    • R9 Series
      • R9 Fury Series
      • R9 390 Series
      • R9 380 Series
      • R9 290 Series
      • R9 280 Series
      • R9 270 Series
    • R7 Series
      • R7 300 Series
      • R7 260 Series
    • R5 Series
    • Others
    • HD 7000 Series
  • Technology
  • Market Place
    • Hot Deals
    • For Sale or Trade
  • Warranty questions
  • Never Settle Campaign
  • News
Club 3D Insights
  • Unfollow
  • Follow
  • Profile
  • Logout
que cable club3d debo comprar
Updated on 30-09-2025 in Adapters and Cables.
  • Close
  • Delete
7 0 on 14-02-2025
franxxx
buenas tengo un monitor lg 32gs95uv y quisiera saber cual es el mejor cable club3d que deberia comprar para dual mode 480hz, modo sin dual mode 240hz etc, no veo ninguno en la web si alguien me puede ayudar se lo agradeceria, un saludo y gracias.
Save Cancel
1 0 on 15-02-2025
joevt
Hello, I have an LG 32GS95UV monitor and I would like to know which is the best club3d cable that I should buy for dual mode 480hz, mode without dual mode 240hz, etc., I don’t see any on the web, if someone can help me I would appreciate it, greetings and thank you.
From franxxx
The product page says you have two connection choices:
DP 1.4 or HDMI 2.1
If you have a GPU that supports HDMI 2.1, then get a 48 Gbps HDMI 2.1 cable.
Otherwise, get a 32.4 Gbps DisplayPort 1.4 cable or a 80 Gbps DisplayPort 2.1 cable which should work just as well.
Save Cancel
0
franxxx
buenas gracias por la respuesta mi grafica pone 1.4a pero ¿crees que me valdra este? de club3d
DisplayPort™ 2.1 Cable certificado VESA DP80 8K240Hz 1.6m/5.25ft, un saludo y gracias
Reply Cancel
2 2 on 16-02-2025
joevt
DisplayPort 1.4a is slightly newer than 1.4. It requires the same cable bandwidth.
https://en.wikipedia.org/wiki/DisplayPort
Yes, the Club 3D CAC-1092 DisplayPort™ 2.1 VESA DP80 Certified Cable 8K240Hz 1.6m/5.25ft should be more than sufficient for your purpose.
Another cable that should work is the Club 3D CAC-2068 DisplayPort™ 1.4 HBR3 Cable VESA Certified M/M 2 m / 6.56ft 28AWG
Save Cancel
0
Wiktor
True that!
0
franxxx
muchas gracias comprare el 2.1 y asi compruebo si hay alguna mejora con el cable 1.4a que suministra lg que es una duda que tengo, lo que no se si comprarlo bidreccional o no, un saludo, ya comentare si hay alguna mejora con el que trae, gracias
Reply Cancel
0 0 on 17-02-2025
joevt
Uni and Bi-directional cables are discussed at:
https://www.club-3d.com/en/technology/16/uni_and_bi_directional/
Both the CAC-2068 and the CAC-1092 are bi-directional.
I don’t believe either cable should provide any improvement compared to the DisplayPort cable that comes with the LG 32GS95UV unless that cable is damaged.
Save Cancel
Reply Cancel
Login to Reply
Reply Cancel
  • All Posts
  • Following Posts
  • Blog
Copyright 2026 Club 3D B.V.
