Two of my monitors would be conected via miniDP and the other one on a dvi to vga adapter now im not shure if that will work or not…
Dear Gezoriugi, thank you for contacting us. Can you share information about your setup? Many cards support a triple screen (Eyefinity) setup but require (at least) one active adapter cable to make it work.
Thanks thats all what i wantet to hear, cause im not going to buy an active adapter
what means im going back to two Monitors. (Im also not using Eyefinity)
My Setup:
GPU: 2x Club3D R9 280X
Cpu: Intel 4790K @4.6Ghz
Ram: 20Gb. (mixed and matched)
Psu: 850W Super Flower Leadex
Monitors:
2X Samsung S24C350
1X Acer X223w
(the stuff that i didn’t mentioned is less important anyway)
If you don’t use Eyefinity you should be able to get a triple screen setup working directly from the card. But the Acer monitor you mention seems to have a VGA (analog) input only. Since the 280X only features digital outputs you would need an active adapter to from either mDP to VGA or DVI-D to VGA.
Notifications
