Club 3D CAC-1010 doesnt work with anything higher than 60hz
Updated on 17-04-2022 in Adapters and Cables
2 on 09-04-2022
So as the title says it just doesnt work no matter what resolution i set it to and anything higher than 60hz with a xl2411 monitor and 1060 gpu.
Is there anything else that shud be changed for this to work?.
It works just fine with 1080p and 144hz if i put the dvi cable straight into the gpu
1 on 11-04-2022
Have you every updated your firmware on the 1060?
https://www.nvidia.com/en-us/drivers/nv-uefi-update-x64/
Drivers up to date?
Do you have more displays connected to your GTX? If yes disconnect one see what it does.
on 17-04-2022
Got it solved by using a dif displayport… apparently one of them cant go higher than 60hz for whatever reason… did get a dif problem with the colors and some blurryness but kinda got that solved too by changing some settings in the nvidia driver (color range limited to full).
