Hi
Ist it possible to use this config?
AngstHab
Dear AngstHab, thank you for your information. It’s not likely that connecting an MST Hub to the Aten-KVM switch will work because MST Hubs need to be connected to the native DisplayPort output of the GPU.
What is the configuration of the system you are using? Thanks.
Notifications
