Club3d compatibility with Acer XB271Hu Monitor
Updated on 17-02-2020 in Adapters and Cables
4 on 17-02-2020
Good day,
I just purchased this cable: DisplayPort 1.4 HBR3 Cable M/M 2m/6.56ft.
My concern is that is my monitor ACer XB271Hu is compatible with the mention cable? My monitor has a 1.2 dp port with hbr2 speed And as i saw the cable is 1.4 with hbr3 speed and 20pin.Is the 20th is connected? I mean it doesn’t deliver any power in it?What I have read on the other forums that if 20th pin is connected it can cause problem either in the monitor either in the computer(VGA). Please answer for me that am I able to use this cable safely with my monitor without any problem? Or do you recommend to use the cable out of the monitor box?
I just wanted to change it for the premium cable to get most of out my monitor.
Thanks for your replies.
0 on 17-02-2020
Hello Selynelar,
you can be assured that it works, I have no idea where you get your information form but. DP 1.4 Cables are fully backwards compatible.
https://en.wikipedia.org/wiki/DisplayPort
Please read this carefully and then you can check the sources below the article, most Club3D cables are VESA certified. Vesa is the creator of Displayport they will not certify cables that break your monitor, if that was the case Displayport would no longer be used 😉
A cable has always a connector reserved for power, this has been that way since DP1.0 all up to DP1.4
Enjoy your premium cable 😀
1 on 17-02-2020
Thank you. I believe my quiestion was confusing.  Basically my question is this one
:https://insights.club-3d.com/thread/club-3d-cac-1060-dp-cable-pin-20-connected/
Only the different is the type of the cable 🙂 Thanks.
on 17-02-2020
Hi,
I understand now you wanted to know if pin 20 was disconnected.
Yes it is thank you for clarifying. 🙂
0 on 17-02-2020
Thank you sooo much. This what i wanted to know. So now I can be sure that the pin 20 is disconnected. You are the best. I am looking for this answer already a week 😀
Best Regards,
Janos Panic
