Hi,
Currently I use the ‘ USB Type C Cable to DisplayPort™ 1.4 8K60Hz’ (CAC-1557) to connect my Macbook Pro to my external monitor.
(A IIyama G-Master Red Eagle 34 inch monitor)
I also use this monitor with my PC.
As I work with Illustrator and Indesign a lot, color accuracy is quite important.
So the problem I have is when I connect my macbook to my monitor the colors aren’t bright and a bit dull. I don’t have this problem when I use my monitor with my PC (HDMI to Displayport cable)
Is it possible this does have anything to do with the cable I use, or could it be an Macbook / Apple problem? And could it be fixed in any way?
