Connecting 30″ Apple cinema monitor to MacBook Air (M2, 2022) issue
Updated on 18-08-2022 in Members Lounge
2 on 18-08-2022
Hi there
I just got the new MacBook Air (M2, 2022). I’m trying to hook up my 30″ Apple cinema monitor. It used to hook up to my 2018 MacBook Air but when I used the same connection the 30″ showed 3x cut-off monitor extension images. (not sure how to describe it)
I purchased the CAC-1510 connector because it said I can plug in the serial port and then into my computer. The apple screen stays black even though it is showing up as active in the systems display area.
Any ideas?
Thank you
0 on 18-08-2022
I believe you would needed the CAC-1510-A. Contact support@club-3d.com for a firmware update.
0 on 18-08-2022
Thank you for your response.  I have a message into them now.
Thanks!
