HELP!!
I have the same issue with the CSV-1564W100 USB Type C 3.2 Gen1 Triple Display Dynamic PD Charging Dock…only the flashing happens a lot and my 2.4 dongle keyboard often has to be reconnected.
I have a HP Envy X360 15-eu0013ca with 2 TV’s connected as monitors:
a Samsung UN55MU6300 connected by HDMI and
an older Philips Tv connected from TV with single cable that is HDMI to DP on the dock.
The worst flashing is when on Zoom calls with multiple people and the strange part is that the flashing while on zoom is contained to the other people’s videos, the menu and the main window do not flash just the other participants videos go on and off repeatedly, Sometimes I have noticed resizing to a smaller window eases it a bit but it still does it. And once in a while using other programs and doing different things the flashing will happen but not as intensely as on Zoom and it is not consistent, and it starts randomly it seems and then flashes more and more and the cameras are not visible for longer and longer periods as the call goes on in length!
HELP I have tried uninstalling all display, camera and video software and reinstalling and Zoom software as we’ll, I have installed older versions of Zoom also and it still does it.
I can’t find any drivers for the dock so I don’t know how to uninstall and reinstall anything for it that would make it better!
Please help if you can, as I really don’t want to have to buy a new dock.
Thanks for any and all help you may be able to provide,
JJ
