Hello, I got the CSV-1568 dock. I connected it to my Macbook Pro (2021). So far everything is working, except the LAN connection. The LAN cable is plugged into the switch, the orange light on the dock is on, the green is blinking. While it works on my other PC, it does not work for the Macbook. Can you please help?
Thank you!
