• All
  • Members Lounge
  • USB Type C
  • Docking Station
  • MST Hub
  • USB Graphics
  • Adapters and Cables
  • Graphics cards
    • R9 Series
      • R9 Fury Series
      • R9 390 Series
      • R9 380 Series
      • R9 290 Series
      • R9 280 Series
      • R9 270 Series
    • R7 Series
      • R7 300 Series
      • R7 260 Series
    • R5 Series
    • Others
    • HD 7000 Series
  • Technology
  • Market Place
    • Hot Deals
    • For Sale or Trade
  • Warranty questions
  • Never Settle Campaign
  • News
Club 3D Insights
  • Unfollow
  • Follow
  • Profile
  • Logout
DisplayPort and HDMI to DVI-i cable or adapter
Updated on 27-05-2020 in Others.
  • Close
  • Delete
3 0 on 14-05-2020
Pfrz
Guys, this question is for the experts.
I am a photographer, and that means that I have to calibrate my monitors for correct color. Some of my clients are very, very nervous when it comes to the color or their products.
I use an NEC Multisync LCD2690 WUXi monitor, one of the best for that purpose. Though it’s pretty old it is extremely capable of displaying a huge range of colors, far beyond consumer or prosumer monitors. The killer feature is that it can be hardware calibrated. In a nutshell:
Hardware calibration is the method of adjusting color directly by adjusting the settings inside the monitor. With hardware calibration, the target color is not reproduced through the graphic card output where all or a certain combination of white point, gamma, and brightness are reduced.
That means, I get the most out of this monitor by using the hardware calibration feature – and that requires to use the right connection to the computer. This monitor has two main inputs: DVI-D and DVI-i. The only way to go is DVI-i. DVI-D does not allow hardware calibration.
My workhorse computer is a Lenovo Thinkpad W520 (e.g. a fast Intel i7/32GB workstation shaped as a notebook) has a DisplayPort outlet, the other has HDMI. In both I cannot fit a new graphics card with a DVI-i plug.
Getting a cable or adapter to connect DisplayPort or HDMI to DVI-D is a no-brainer. But what I try to find is a cable or adapter or combination to DVI-i with full functionality.
What I found here was this one:
https://www.club-3d.com/en/detail/2479/displayport_auf_dual_link_dvi_i_aktiver_adapter/
The description is a bit confusing. It is declared as DVI-D but in the pictures I see a DVI-i plug.
So, would that work? Or is there a better choice?
Save Cancel
0 0 on 14-05-2020
MST1407
Hi there – the puzzle here is that DVI-I only will allow hardware calibration. does it mean that you need an analog signal to arrange calibration or ? The reason why Club3D uses the DVI-I connector is so that it will fit Analog as well as Digital connectors – but since the source signal is DP that means that it will only support DVI-D (digital) signals.
Save Cancel
Reply Cancel
0 0 on 14-05-2020
Pfrz
Hi, MST… I must say: I have no idea why exactly DVI-i is required. What can we do to find out?
Save Cancel
Reply Cancel
0 0 on 27-05-2020
MST1407
I would say the adapter CAC-1010 should be able to work in your setup – DVI – I is mainly functional for Analog and Digital – in this case you will be using a Digital Signal / DP is always Digital.
Save Cancel
Reply Cancel
Login to Reply
Reply Cancel
  • All Posts
  • Following Posts
  • Blog
Copyright 2025 Club 3D B.V.
