I’m having trouble connecting to KS8000 UHD HDR-enabled TV with CAC-1080
Updated on 22-03-2019 in Adapters and Cables
1 on 21-03-2019
I’m having trouble connecting to KS8000 UHD HDR-enabled TV.
There is a screen flicker (pull) that is sustained when set in the Lo-Envidia control panel. I looked up the internet and found that firmware update is possible. Please tell me how.
My computer’s display resolution and color settings are:
GTX 1080ti
3840 2160
60hz
8bpc color deep
RGB
Full range
0 on 22-03-2019
Hello Cheng,
Thank you for your question. for HDR to work the bit output should be 10bpc (10bit).
Could you aslo take a look at the following link to make sure you are running the latest firmware for your videocard.
https://www.nvidia.com/object/nv-uefi-update-x64.html
may i ask what do you mean specificaly with the Lo-Envidia control panel?
I hope this will contribute to a solution.
Kind regards
