MST problems
Updated on 16-02-2018 in MST Hub
17 on 05-02-2018
I have a Radeon rx 580 running on Win 10 64 bit…..three identical monitors (hdmi) When I connect the MST hub I can get two monitors but not three…..when I connect the third all monitor than say “input not supported” the hub is connected to display port and it is a three port hub…..at a total loss here am I doing something wrong? Any help would be appreciated
4 on 06-02-2018
well I must say after quite a few hours this purchase has been a major disappointment
on 06-02-2018
Hello Hadog,
Sorry to hear that.
Which MST Hub do you have (for instance … CSV-5300A / CSV-6400 / CSV-6200H)
We have heard more initial issues with some Driver versions for RX generation with regards to use of Eyefinity feature.
Which driver version are you currently using ?
on 06-02-2018
hello and thanks I am going nuts here hahahah I have the 5300A uding the lastest drivers 18.2.1 been trying every cable/adapter I have tried a different monitor…..clean uninstall of drivers fresh install…….I have two AMD cards (not in the machne at the same time) and they are both having the same problem
on 07-02-2018
would it be possible that the monitors are the problem….using Acer monitors hdmi connection….they are not new 4 years old at least I have been trying every combination…the best I can do is to get the three up and running but when I try eyefinity I get the input not supported doesnt matter if I use your hub or individual active adapters
on 07-02-2018
Hello Hadog,
An MST Hub is an active device so you should use passive adaters plus normal HDMI cable that comes with the screens, to connect your HDMI Monitors.
Like these: CAC-1001
http://www.club-3d.com/en/detail/2373/displayport_to_hdmi_passive_adapter/
Any particular reason you choose for the CSV-5300A instead of the CSV-5300H ?
3 on 07-02-2018
no reason I choose the 5300a. I am at a loss here I have the hub and it has hdmi ouports do I still need an adapter?
on 07-02-2018
Hello Hadog,
IF your MST Hub ahs HDMI outputs than you have the CSV-5300H.
And no then you would not need adapters, just normal passive HDMI Cables to go to Screens.
on 08-02-2018
when the 5300a arrives do I use passive or active adapters? Just want to make sure
on 08-02-2018
passive adapters
3 on 08-02-2018
thanks will let you know the results
on 09-02-2018
please do 🙂
on 13-02-2018
nope same issue…input not supported …running the new hub 5300a with three passive adapters…….one monitor works…when i hook up the second it duplicates the first monitor screen (I can not extend the screens no option appears  to do so  When I hook up the third monitor I get input not supported on all three….running the r9 200 series card will try the other card tomorrow not happy at all
on 13-02-2018
Hello hadog,
That indeed does not sound good, which is very odd.
To make Eyefinity work, you need WIN Vista or newer and use the DP1.2 ouput on the Graphics Card. MultiStreamTransport (MST) feature is supported by DisplayPort 1.2 spec and WIN, meaning grpahcis cards with DP1.2 ouput are able to output multiple video streams over a single DP1.2 output. An MST Hub is able to recognize and distribute those video stream (with sound even) to connected screens.
Some screens need to be set to DP1.2 for the DP input in the menue of the screen (factory default would be DP 1.1).
MST Hubs are active devices and do not work well together with other active devices like Active adapters / Cables/ Switches / CrossFire / SLI setups.
Thats it, shoul dbe like “nothing more to it” …
3 on 13-02-2018
after lots or reading I think it is a windows 10 problem…many users have reported problems with multimonitors after they upgraded to the latest version of windows. My card is fine, cables and monitors are fine the hub is fine. Eyefinity crashes and reports input not supported but I think that is happening because of the windows problem….no matter what is attached the problem seems to be traced back to windows. Sooo i am going to sit back and wait for the next upgrade hahhaha Many thanks for your help. If I ever get it resolved I will let you know for sure
on 13-02-2018
could also be a driver issue … perhaps try a driver version from before RX400 / 500 series came out.
Not sure if your card will accept it but 16.8.3 was a really good driver and 17.2.1 was also quite ok.
https://support.amd.com/en-us/download/desktop/previous?os=Windows%2010%20-%2064
on 15-02-2018
As you know I have been going through this problem for a while and I have tried almost everything I can think of and what you suggest…so I go back to the beginning,,,input not supported ….the monitor is the input, But they appear fine settings are all in order I have a new fourth monitor hanging around so I hook that one up thus removing one of the Acers……everything works …..hub is fine eyefinity is fine everything is fine (unless it all comes crashing down tomorrow hahahahah)  Many thanks for your support  much better than AMD and MSI who still havent replied!!!
on 16-02-2018
glad to hear you got it working 🙂
Thanks for the feedback.
