need driver club3d hd5770 help pls
Hi Lethu,
try this site
https://www.amd.com/en/support/graphics/amd-radeon-hd/ati-radeon-hd-5000-series/ati-radeon-hd-5770
non accetta nessun driver amd. installando la suite si blocca non riconoscendo l’hw
non accetta nessun driver amd. installando la suite si blocca non riconoscendo l'hw
Did you DDU the old drivers first?
It is also not that weird it’s not working. The card is almost 14 years old….
It is also not that weird it's not working. The card is almost 14 years old....
1 Black screen for milliseconds with CSV-7200H
2 CAC-1088 support for 2560x2880 resolution
3 CAC-1088 Question
4 CAC-1087 Fails HDCP support verification with PDVD 21
5 2080ti RTX DP 1.4 -> HMDI 2.1 adapter? (4K/120hz/HDR/G-Sync)
6 Sinks or adapters using MCDP2900 DP to HDMI converter chip?
7 VRR support on CAC-1085 and 1088
8 Can this ever exist? female DP to male HDMI
1 MST1407 1.3K 28
2 Baak 610 23
3 joevt 466 70
4 Paul 458 40
5 CLUBBIE 269 9
6 RoyalKing 153 15
7 Pittyh 60 3
8 net200777 56 2
9 ost 53 13
10 Mu7ammad 44 4
You need to log in to upload images from your computer.
You can also sign in by :
Enter the destination URL
Or link to existing content
