So usually i was playing on my 42″ flat screen but since i wanted a pc monitor to get a better picture i changed down to a 27″ Samsung now…
The old 42″ ran on Hdmi and has never been a problem. The new 27″ tho cant connect to my uncles pc without a problem, but on my RoyalQueen it only wants to use the DVI input which apparently cant go further than 1600/1200 which should be able to go to 1920/1080.
Problem is i want to use the HDMI and want the 1920/1080 again on my new monitor i have tried disabling onboard gfx card to see if that was the problem, i’ve even run the monitor with HDMI on the onboard gfx card and that wasnt a problem.
So im thinking i need a bios update for the gfx card but how to get that ? and or do you guys have any other tips or tricks ?
Also at the start my monitor would show a generic pnp monitor, now it actually says in the device manager that it is a samsung(model number) HDMI…
But still only working through dvi.
help ?
