Good afternoon,
it’s about the adapter “CSV-1537”.
Is it possible to connect a monitor via HDMI and charge it via USB-c at the same time?
Amazon says that this is not possible.
Greetings
Thomas
Hello,
do you mean the CSV-1534
https://club-3d.com/en/detail/2386/usb_type_c_to_hdmit_2.0_usb_2.0_usb_type_c_charging_mini_dock/
“Is it possible to connect a monitor via HDMI and charge it via USB-c at the same time?”
I presume you mean charging a USB Type-C enabled notebook?
the answer is yes, however your notebook should support USB Type-C Displayport alt-mode to put out a video signal.
What Notebook do you use?
Hello,
Correct a macbook pro 15inch is not able to be charged with this adapter, since the adapter has a Max output of 60watts and the macbook 15inch needs 87 watts to charge.
