• All
  • Members Lounge
  • USB Type C
  • Docking Station
  • MST Hub
  • USB Graphics
  • Adapters and Cables
  • Graphics cards
    • R9 Series
      • R9 Fury Series
      • R9 390 Series
      • R9 380 Series
      • R9 290 Series
      • R9 280 Series
      • R9 270 Series
    • R7 Series
      • R7 300 Series
      • R7 260 Series
    • R5 Series
    • Others
    • HD 7000 Series
  • Technology
  • Market Place
    • Hot Deals
    • For Sale or Trade
  • Warranty questions
  • Never Settle Campaign
  • News
Club 3D Insights
  • Unfollow
  • Follow
  • Profile
  • Logout
7850 and samsung
Updated on 20-10-2016 in HD 7000 Series.
  • Close
  • Delete
1 0 on 18-10-2016
zebulon
i have 4 samsung s e650 (1980×1080) connected using mini display port to display port 1.1 cables.
one screen does not give a picture. can you help?
Save Cancel
0 0 on 20-10-2016
MST1407
Which HD7850 do you have ? Club3D CGAX-7856M6 ?
For a HD7850 card to be able to support more than 2 screens the Eyefinity Feature needs to be enabled. You do that by using a Displayport Output. OS needs to be WIN Vista or newer.
When using Screens with Displayport Input you can use Passive Adapters / Cables to connect from Card to Screen. (Although we always advise to use at least 1 active version, because in practice that seems to work better)
When using Screens without Displayport Input you need to use Active Adapters / Cables to connect Screen 3/4/5/6.
The first 2 are always natively supported so they can be connected with passive adapters at all times, although it will of course also work with Active Adapters.
Passive Adapters:
CAC-1100 = Mini DP to DVI Passive Adapter
http://www.club-3d.com/index.php/products/reader.en/product/29.html
CAC-1101 = Mini DP to HDMI 1.4 Passive Adapter
http://www.club-3d.com/index.php/products/reader.en/product/mini-displayport-to-hdmi-cable.html
Active Adapters:
CAC-1152 = Mini DP to DVI Active Adapter with Eyefinity Support
http://www.club-3d.com/index.php/products/reader.en/product/mini-dp-to-active-dvi-single-link-cable.html
CAC-1170 = Mini DP to HDMI2.0 Active Adapter with Eyefinity Support
http://www.club-3d.com/index.php/products/reader.en/product/mini-displayport-12-to-hdmi-20-uhd-active-adapter.html
Technical Info on Eyefinity:
http://www.club-3d.com/index.php/technology/amd-eyefinity.en.html
Save Cancel
Reply Cancel
Login to Reply
Reply Cancel
  • All Posts
  • Following Posts
  • Blog
Copyright 2025 Club 3D B.V.
