Hi,
I think this is the right place to submit my problem.
I’m using a MST 1.2 (Club3D CSV-5200 type 1.2a) on the DP port of my my ASUS CG8270 – AMD Radeon HD 7770 1MB graphic card.
On the MST display ports, i connected one active DP to DVI adaptor and one active DP to VGA adaptor towards two identical 27″ Iliyama screens 1920×1080 (model E2773HS).
The two screens work on the same and correct resolution, but CCC and windows identify them as one and the same screen, so they are duplicated. It doesn’t recognise them as screen 1&2 and there’s nothing i’ve been able to do.
CCC catalyst does not show the “displayport diagnostics” option, as i believe it should.
No other cables are connected on the other GPU outputs (2xDVI)
What am i doing wrong here?
Thanks for your reply,
Laurent
