CAC-1051 Flicker Problem
Alright so I have a CAC-1051, for those who don't know it is a DVI-D to Displayport adapter that I use to connect my moniter to my computer.
I have had pretty good experiences with it so far, the 144hz, but the main problem I have had with it since purchase is that it flickers black snow every 5 minutes or so. The flicker lasts for like half a second. I can tell that it is snow static.
My graphics card : AMD RX 480
Moniter : Acer GN246HL
Adapter : CAC-1051
Driver Version : 16.12.2
Is this hardware or software? I have heard that a lot of adapters like these have flicker problems, and want to find a solution.
I have the exact same problem with this adapter (however sometime the flicker last 4-5 seconds). My configuration is different as I have a Dell 3007WFPHC and an Intel HD Graphics 520 and the resolution used is 2560x1600 at 60Hz.
I thought that it was maybe related to the USB power but I tried different ports with the same result. Is there a simple solution or check to do?
Hi greatpatton,
Nicholas, was running 1080 at 144Hz on a AMD Graphics, so indeed different from your setup. Result very similar though, and certainly not what it should be !
I will have [email protected] send you an email.
