I”m using the Club 3D, CAC-1170 along with you USB Cable to attempt to connect an LG 34UM58 Ultra Wide Screen Monitor. It does not work, I get no connection on the monitor. When I use a normal Mini Display adapter to USB it works but only at 1080p. The reason I bought your Club 3D, CAC-1170 was so I could use the monitors higher resolution capabilities.
Software OS X 10.9.5 (13F1911)
NVIDIA GeForce GT 120 512 MB
Processor 2 x 3.33 GHz 6-Core Intel Xeon
Insert Image
