No RGB to YCrCb conversion on CAC 1080
1 reply
Hi
I use the CAC-1080 with Nvidia GTX-1050 in Linux. Unfortunatly NVIDIA can only output RGB 10 Bit when the Adapter is connected. But my TV needs YCrCb 4:2:0 10 Bit. How can I tell the adapter to convert from RGB to YCrCb 4:2:0. Currently it just output also RGB to the TV.
I also updated the Card already with the patch for DP-1.4 from Nvidia.
Hello jojo61,
Unfortunately you cannot really tel the adapter "to output to convert from RGB to YCrCb 4:2:0".
You can only tell your Graphics Card to do so, in the Graphics Driver Software you should be able to do so. Sometimes you will need to make a custom resolution for this.
