CAC-1070 Sound problem
Updated on 28-02-2017 in Adapters and Cables
2 on 16-01-2017
Hi,
Recentlly i bought this adapter to connect my Nvidia GTX 1080 to an Onkyo 626 AV Reciever, but i only manage to get stereo sound. With the hdmi cable i have 5.1 sound. I need to connect acroos de displayport output because i need the hdmi connection for another porpouse.
And other problem i have sound cuts at any time playing music, internet videos o videos form my computer.
It is any solution to get 5.1 and hd sounds across this adapter? and for the sound cuts?
(sorry for my bad english, i´m from spain)
Thank you.
0 on 23-02-2017
What mainboard are you using?
Maybe you can output the audio by spdif/optical..
0 on 28-02-2017
please make sure to turn off all the scaling options the Receiver might have.
Please check if the HDMI Cable is HDMI2.0 / 18Gbps capable. The fact that it does 5.1 sounds over HDMI1.4 does not mean it also can doe 18Gbps …
i will ask support@club-3d.co to send you latest firmware for the adapter.
