I’ve bought Club3D DisplayPort – USB-C cable CAC-1557 but I have an issue with it.The cable works fine when I try to connect my phone (android, USB-C) to an external display that accepts signal via DisplayPort. I can mirror my phone’s screen and everything functions perfectly… however…
When connecting DP to my RTX3080 and USB-C into external monitor nothing seems to happen. I cant see the monitor being connected in windows nor in Device manager. It’s as if the cable has no connection at all. This is my primary use case and I specifically bought this cable because it claims to be bi-directional.
Browsing this issue I’ve found the thread (https://insights.club-3d.com/thread/gpu-display-port-1-4-to-lg34wk95u-with-usb-c-cac-1557/) that seems to be having similar issue. However, I wasn’t able to find a link to the firmware update that was mentioned there.
Is there anything else I can do besides e-mailing support on this issue? Thanks!
