CSV 5300 Problem
Updated on 03-03-2015 in MST Hub
1 on 02-03-2015
I have a trifire of 290 and 3 Asus VG 248QE 144Hz
I plug the hub in my display port and no DP signal detected on my screen. I plug a DP to DVI in the hub and it works.
To have my 3 screen work, I have 2 DVI and one DP to DVI. I tried the DP from my screen to another video card and the screen works.
I tried 5 different cable and it is always the same result. When I plug a DP in my card directly it doesn’t work but with a DP to DVI it works.
0 on 03-03-2015
Hi,
I strongly suggest to deinstall the catalyst driver and reinstall the driver first by using a single display.
Once the driver is installed, turn off the system, power off the system and drain the power by pressing the on button on your pc (make sure that the power supply is disconnected from the power cable.
Place everything back again, connect the mst hub to your displayport output, the 3 displays and power on the system. You probably will see all screens on or just a single display. Proceed to configure your display arrangement.
