Display driver amdkmdap stops responding and has recovered .
Updated on 14-09-2015 in R9 280 Series
1 on 14-09-2015
Hello my name is Sui,
I have a problem with my video card, I hope you can help me here, I have searched various forums but could not find the same problem, unfortunately, not so I thought I seek help at the forums of the manufacturer side itself. The problem is that the game keeps crashing or fail after a certain time about 10 min. This problem only occurs in heavy games like GTA 5, Crysis 3 or Fallout New Vegas. When I check the logs I see the following message “Display driver amdkmdap stops responding and has recovered” I suppose it has to do with the graphic card. previously I had another graphic card and has always worked well, after I installed this graphic card, these problems were created. I have after installing graphics entire reinstalled windows and installed all necessary drivers. I hope you can help me with this, I am open to all questions and tests that must be done .Mijn english is not so good so I try as much as possible via google translate to explain everything properly. Here I describe my system see features below :
Windows 8.1 Enterprise Proffesional
CPU:Amd A8-3870 APU with Radeon(tm) HD Graphics 3.00 GHZ
RAM: 8 GB Kingston (PAE)
SSD 240gb Pny optima
Club3d 280x Royalqueen
coolermaster 750 watt
thank you for your efforts and assistance
0 on 14-09-2015
