I have viewsonic 4K oled portable monitor. Just bought this cable to connect that monitor to my PC with display port (rtx 4070 ti super). Tried switch all among all the GPU display ports, but nothing work.
The cable is CAC 1559.
Is it this one?
https://www.viewsonic.com/global/products/lcd/VX1655-4K-OLED#specs
Does it work with the mini HDMI to HDMI cable?
Does the PC recognize any additional displays?
Have you tried the joy stick on the back of the display to adjust input?
From the Manual, have you followed these steps?
Power Delivery – Further Information
Due to the VX1655-4K-OLED’s design please note:
The first connected device will be the main input signal.
When a Type C port recognizes an external device as a power adapter, it will only distribute the power. It will NOT display the input signal.
Only when one of the Type C ports is recognized as a power adapter can the other one deliver two-way power.
If a laptop is connected first to the VX1655-4K-OLED, then a mobile phone is connected second, the mobile phone’s battery will not be charged as neither Type C port recognizes the connection as being connected to a power adapter.
NOTE: If you want to display the mobile phone’s screen, you must unplug the Type C cable connected to the laptop.
If a mobile phone is connected first to the VX1655-4K-OLED, then a laptop is connected second, the mobile phone’s battery will be charged as one of the Type C ports is recognized as being connected to a power adapter.
NOTE: If you want to display the laptop screen, you must unplug the Type C cable connected to the mobile phone.
Due to the VX1655-4K-OLED’s design, do not connect two laptops or one laptop and a desktop computer at the same time. This can cause power distribution conflicts, resulting in flashing screens or the forced shutdown of the laptop(s).
NOTE:
If the laptop has a Type C port, please connect via Type C to the VX1655-4K-OLED.
Do not connect the other Type C port of the VX1655-4K-OLED to another laptop or desktop computer via Type A and HDMI at the same time.
If the laptop only has HDMI and Type A ports, please connect via HDMI and Type A to Type C to the VX1655-4K-OLED.
If the power output of the Type A port of the laptop is not greater than 20W, please use our power adapter to connect to the VX1655-4K-OLED.
Do not connect the other Type C port of the VX1655-4K-OLED to another laptop or desktop computer at the same time.
Followed the infos above and still not working. The infos don’t mention anything about Display Port. Could be the monitor just doesn’t work with DisplayPort.
Notifications
