Hello,
I am planning to buy a NUC8I7BEH in the future, my only question would be that, how can I connect three Full HD displays to that?
I have a DELL U2211H, a P2214H and a P2217H.
For the P2214H the manual says:
“*Support DP1.2 (CORE) specification. Excludes High Bit Rate 2 (HBR2), Fast AUX
transaction, Multi-stream transport (MST), 3D stereo transport, HBR Audio (or high data
rate audio)”
For the P2217H it does not say anything about the exclusion of MST, only that it has a DP1.2 port.
I do not ha DP Out on any of these displays, therefore daisy chaining is not possible.
Can I use an MST Hub in this case?
The “Excludes […] Multi-stream transport (MST)” does not really fill my heart with warmth and I am afraid because of the DP1.1a on the U2211H there will only be mirrored image for one of my displays.
What would you recommend?
Thanks!
