Using USB 3.0 Active Repeater Cable 10 m/ 32.81 ft Male/Female with Ubuntu
Updated on 23-07-2019 in Adapters and Cables
5 on 16-07-2019
Is it possible to use this product:
https://www.club-3d.com/de/detail/2379/usb-3.0-active-repeater-cable-10-m-32-ft-male-female/with
Ubuntu 18.04?
The datasheet does not list Ubuntu under the supported OS. But if no drivers are needed to use the cable then what could go wrong with using the cable with Ubuntu?
2 on 16-07-2019
Hi Blange,
it is not possible to use this product with Ubuntu the limitation lays within the OS.
on 16-07-2019
Hi Blange,
it is not possible to use this product with Ubuntu. From what I understand Linux USB A ports are designed for peripheral use and not for data transfer. Could you check if thats the case with  your device? If it supports data transfer then you could use the CAC-1402 as specified
on 17-07-2019
Thank you for your reply.
I want to use the USB A 3.0 for video data transfer.
The device I want to use over a distance > 3m is the
ZED Stereo Camera from Stereolabs ( https://www.stereolabs.com/zed/ ).
Which source provided you with the information that USB A is for peripheral use only?
I mean it already works with a cheap active USB 3.0 cable, but I need it to work over a greater distance.
If it supports data transfer then you could use the CAC-1402 as specifiedFrom CLUBBIE
What do you mean with “it” ?
Best regards
blange
1 on 23-07-2019
Hi Blange,
The cable should work since the ZED stereo is able to transfers data, stated on the website of ZED stereo.
I do advice to use the external power adapter that comes with the CAC-1402 since the video is in High Quality.
best regards
on 23-07-2019
Ok, thank you!
I am going to try it then.
