Which cable I need, pls help
Updated on 09-05-2019 in Adapters and Cables
4 on 06-05-2019
I have a question, I have HP elitebook 8760w with 1.2displayport, and I have Samsung UE65MU6502 4K TV. My question is which cable I need to play games at 4k 60hz rgb4:4:4 ?
0 on 06-05-2019
HI Siki001,
in theory you could use any of club3d’s dp cables they all support  Displyaport1.2 and the 1.4 versions support legacy displayport. however i am not really sure your laptop is able to do 4k@60hz at 4.4.4. would u be so kind to let me know what videochipset is in your laptop. so i could check.
0 on 09-05-2019
GPU is Quadro m1000m. Thank you
0 on 09-05-2019
Can I watch movies in 4k resolution? I know I cannot play 4k games 🙂
0 on 09-05-2019
Hi siki001
yes you should be able to 4k @60hz with your videocard. you can pick any of club3d there DP cables. my personal advise is the CAC-1062 it is a 5 meter 1.4dp cable, it is long enough and future proof it could do 8k @60hz (ofcourse if supported by the source device)
