• All
  • Members Lounge
  • USB Type C
  • Docking Station
  • MST Hub
  • USB Graphics
  • Adapters and Cables
  • Graphics cards
    • R9 Series
      • R9 Fury Series
      • R9 390 Series
      • R9 380 Series
      • R9 290 Series
      • R9 280 Series
      • R9 270 Series
    • R7 Series
      • R7 300 Series
      • R7 260 Series
    • R5 Series
    • Others
    • HD 7000 Series
  • Technology
  • Market Place
    • Hot Deals
    • For Sale or Trade
  • Warranty questions
  • Never Settle Campaign
  • News
Club 3D Insights
  • Unfollow
  • Follow
  • Profile
  • Logout
CAC-1051 flicking and shifting
Updated on 21-11-2017 in Adapters and Cables.
  • Close
  • Delete
3 0 on 17-11-2017
Greed
Hello, the Apple CinemaHD 30 monitor, the sapphire vega 56 video card. in the moments of peril, the image disappears for a fraction of a second, then the ripple appears, then switches back to normal mode, appears under different conditions – in games, in the browser, when watching video. power saving off (including usb power saving off) windows 7, mb asus z87m adapter club3d cac-1051 id:4891038, ean:8717249408475
Save Cancel
0 0 on 20-11-2017
MST1407
Good day Greed,
Sorry to hear this.
Sounds like the adapter looses signal from the Graphics Card.
Can you check which firmware is on the Adapter, should be something mentioned on the dislayport cable normally.
Are you able to test the adapter on a different system by any chance ?
Save Cancel
Reply Cancel
1 0 on 21-11-2017
Greed
Hello, I found one request on your forum (CAC-1051 screen-flicking and shifting (DP to DVI-DL active adapter)) and downloaded the firmware and program provided there. After the firmware is updated, the problem occurs only once when the desktop is loaded. Loss of signal is unlikely due to the lack of signal propagation on the parallel connected tv in hdmi.
Again, just in case, after flashing to the version from the post CAC-1051 screen-flicking and shifting (DP to DVI-DL active adapter) (https://insights.club-3d.com/thread/cac-1051-screen-flicking -and-shifting-dp-to-dvi-dl-active-adapter /), the problem only occurs once the desktop is loaded. The remaining moments of screen-flicking and shifting
have ceased.
Save Cancel
0
MST1407
Ok,  yes that 2.33 is the latest available firmware we have.
Please connect DP port to the first DP output, which is normally the one on top (furthest away from the HDMI output). Set screen connected via the Adapter as secondary screen and mirror mode (just for now to try to get it going) and turn off all power saving settings in screen and system.
Reply Cancel
Login to Reply
Reply Cancel
  • All Posts
  • Following Posts
  • Blog
Copyright 2025 Club 3D B.V.
