CAC-1051 max. resolution 1920×1080
Updated on 11-06-2018 in Adapters and Cables
1 on 11-06-2018
Hello,
the CAC-1051 did not support a resolution greater than 1920×1080. The CAC-1051 is installed between Lenovo P51 Workstation Dock (DisplayPort) and Uniclass KVM-Switch AL-834ASK (DualLinkDVI).
The problem was solved with newer firmware for the CAC-1051 (version 2.33 instead of 2.19).
Source: https://insights.club-3d.com/thread/cac-1051-screen-flicking-and-shifting-dp-to-dvi-dl-active-adapter/
Is there a newer firmware version?
Sincerely
Holger Klinge
0 on 11-06-2018
Good day  hklinge,
Good to hear you got it working 🙂
and no we do not have newer firmware that the 2.33, that is indeed the latest
