CAC-1332 work with ps5 and ultrafine 5k(new model)?
Updated on 28-06-2021 in USB Type C
4 on 22-06-2021
Does CAC-1332 work with ps5 and ultrafine 5k (new model, the one support iPad Pro)?
0 on 22-06-2021
Is the PS5 able to support 5K? If yes at what framerate? (Hz)
If I google Ultrafine 5K I get a million hits, could you please let me know the exact model you mean.
My gut says PS5 does not support 5K and only 1080P or 4K.
1 on 22-06-2021
LG Ultrafine 5K 4k@60hz (27MD5KA-B)
on 22-06-2021
Short,
Will it work? Yes 4K60Hz max
Will it display 5K60Hz? No
Still raises the question. Does the PS5 even support 5K resolutions? Afaik it does not even support 2K and only 1080P or 4K.
0 on 28-06-2021
27MD5KA is the Thunderbolt only model. You need a 27MD5KL to do USB-C input.
With the 27MD5KL, 4K60 may be possible from the PS5. If there was a way to use a custom resolution on the PS5 and the PS5 supported 5K width, then 5K39 would be possible (but this is unlikely). I’m not sure if the 27MD5KL can accept 1080p. It does support 1440p.
