My display is not detected and I keep getting an error message “Display connection might be limited”, is there any solution to this problem? I’m running windows 10
Hello BrendanOG,
Sorry to hear this.
What system do you have?
What Graphics Card or Integrated Graphics is inside?
What Screens do you have (Brand/Type) and how are they connected?
Thanks
Hello BrendanOG,
To be able to send a Video Signal over a USB C port the notebook needs to have support for DisplayPort Alternate Mode. Did you check if DP Alt Mode is supported by the HP pavilion 15-cw0509sa … (I coud not find it oinline)
Also you said you have 2 screens, how do you connect the other ?
Hi,
If you click on the link to the specifications and scroll down to the external connections section you will see that the system supports Display Port 1.2, although I don’t know if this means that it is DP Alt Mode compatible. The other screen is connected via HDMI.
https://support.hp.com/ie-en/document/c06060773
Brendan
Hi BrendanOG,
That is very odd. We do not get such error here on any of the screens we tested. We will forward the issue to our tech-team adn get back to you asap.
Could you please send us your DX DIAG?
You can just type “DXDIAG” in the search function of windows and the Direct X Diagnostics will open and run, please safe the info and send it over.
Thanks
