CAC-2068 and 164hz problem
Updated on 17-12-2020 in Adapters and Cables
2 on 13-11-2020
Hello,
i just bought that cable for my monitor (dell s3220dgf) i have Gpu Nvidia 1070ti with drivers 457.30
My problem is that i cant use at control panel RGB output color format at all , only YCbCr-422 when my monitor is at 164hz, if i change to 60hz everything is ok (RGB , Full dynamic range , 10bpc color depth)
i tried fresh install nvidia drivers , reset monitor , nothing changed
if i use the Dell’s display port cable that came with the monitor (1,2dp) everything is ok
any ideas what is happening?
0 on 17-11-2020
Hi Throw – could you contact Support@club-3d.com see if they can help you with this. This cable should be able to support this resolution.
0 on 17-12-2020
This cable is shit thats why
