Hi all,
I am trying to connect my MacBook Pro 15″ 2017 with this adapter my Samsung UR55 but the image is distorted and glitchy. I am using HDMI 2.0
Any solution?
Thank you!
I am trying to connect my MacBook Pro 15" 2017 with this adapter my Samsung UR55 but the image is distorted and glitchy. I am using HDMI 2.0
Anyone please??
Hi with a macOSX is always best to create a custom resolution – you can try Switch ResX
Hi with a macOSX is always best to create a custom resolution - you can try Switch ResX
use Simplified Settings at CVT-RB and Pixel Clock at 533.31Mhz
the problem is that the adapter does not seem to work..
I also reading about firmware updates for the adapters that the support sending to users but can not find any in information around can I contact with someone from support?
1 CAC-1335 1440p 240hz Flickering
2 Would the [Club 3D CAC-1335] work with the Bigscreen Beyond Virtual Reality headset?
3 power charger,
4 CSV-1382 how to disable mouse traversal function?
5 Windows 10 64 bit legacy drivers. Club-3D R9 270 graphics card.
6 radeon r9 290 series in an asus 990fx no video
7 Do Club3D CSV-7210 support using both hdmi and displayport for dual monitor
8 CSV-1562 - WOL (Wake on LAN)
1 MST1407 1.3K 28
2 Baak 610 23
3 joevt 466 70
4 Paul 458 40
5 CLUBBIE 269 9
6 RoyalKing 153 15
7 Pittyh 60 3
8 net200777 56 2
9 ost 53 13
10 Mu7ammad 44 4
You need to log in to upload images from your computer.
You can also sign in by :
Enter the destination URL
Or link to existing content
