Connect Cinema Display (20″) to 2019 MacBook Pro
Updated on 05-07-2021 in Adapters and Cables
6 on 01-07-2021
Hi there, have just bought a Club 3D CAC-1510 USB Type C to DVI-I Dual Link Active Adapter 6Z2MG to connect an old Apple Cinema display (20″) to a 2019 MacBook Pro. The display screen flashes on and off for a couple of seconds, but I can’t seem to get a stable connection. Any ideas please?!
5 on 01-07-2021
Hi Petemccormack,
I think you should had bought the CAC-1510-A HDCP OFF version of the adapter. Where are you located?
Please contact support@club-3d.com and describe your issue including hardware used. Perrty sure they will help you.
on 01-07-2021
Hi Baak – oh thanks very much – very helpful!
I’m in the UK. I’ll get on to support@ and see what they say.
Thanks again 🙂
on 01-07-2021
Get this one from Scan
https://www.scan.co.uk/products/club-3d-cac-1510-a-active-adapter-usb32-gen1-type-c-to-dual-link-dvi-d-supports-up-to-2560-x-1600p-6
on 01-07-2021
Cheers Baak. You’re a 🌟
Really appreciate your help!
on 02-07-2021
Just to confirm for anyone that has the same issue – the above suggestion worked and I’ve been able to connect the cinema display to my 2019 MacBook without any issues. Thanks again Baak 🙂
on 05-07-2021
Happy it worked out!
