CSV-1566 USB A to USB C adapter not working
Updated on 25-02-2022 in Docking Station
3 on 24-02-2022
Hi, I have a just received a CSV-1566 USB Gen1 Type-C Triple Display docking station, which I bought because it states in the specifications that:
This Dock is perfectly suited for extending a Type-C port or USB-A port(via a Type-C to USB converter) to provide multiple audio, video, data and power ports
I have connected it to two different machines via a a couple of different USB A to USB C adapters and had no success in recognising the dock at all even as just a USB hub to pick up mouse and keyboard,
The Hub works fine on USB C alone directly to my dell laptop,
0 on 25-02-2022
Did you install the drivers?
• HDMI™ 1 (DP™ Alt mode) supports max 4K/30Hz
• HDMI™ 2 (USB mode) supports max 4K/60Hz
• DP™(USB mode) support max 4K/60Hz
One HDMI requires Alt mode, which you lose when coverting C to A.
Have you installed the drivers?
https://www.club-3d.com/en/detail/2577/usb_gen1_type_c_triple_display_dp_alt_mode_displaylink_dynamic_pd_charging_dock_with_120_watt_ps/
Go to the bottom of the page click downloads and pick your OS.
1 on 25-02-2022
Hi Baak,
Yes thanks I did install updated displaylink drivers from the club-3d website, as i have updated from a Kensington dock for the computers in question. I then went back and uninstalled (on the 2 computers not working with the dock) the divers and used the displaylink clean up utility, and re-installed however still no joy.
I realised that one HDMI would be lost, when using USB A, however I have no video at all, from HDMI or DP, and no recognition or pass though of USB devices like ethernet, mouse and keyboard.
Kind Regards
Paul
on 25-02-2022
Which A to C converter are you useing? As you say the dock works fine directly in USB-C.
I can only think of that converter is not giving enough bandwith, Or the USB-A on the laptop is not USB3 gen1?
