• All
  • Members Lounge
  • USB Type C
  • Docking Station
  • MST Hub
  • USB Graphics
  • Adapters and Cables
  • Graphics cards
    • R9 Series
      • R9 Fury Series
      • R9 390 Series
      • R9 380 Series
      • R9 290 Series
      • R9 280 Series
      • R9 270 Series
    • R7 Series
      • R7 300 Series
      • R7 260 Series
    • R5 Series
    • Others
    • HD 7000 Series
  • Technology
  • Market Place
    • Hot Deals
    • For Sale or Trade
  • Warranty questions
  • Never Settle Campaign
  • News
Club 3D Insights
  • Unfollow
  • Follow
  • Profile
  • Logout
CSV-6400 always needs several plugs/unplugs to work
Updated on 13-03-2021 in MST Hub.
  • Close
  • Delete
5 0 on 10-03-2021
muezli
Hello everyone,
right now I am using a CSV-6400 with 3 screens.
In the future there might be a chance, that I’ll upgrade to a 4-screen-setup, but for now it will be a 3-screen-one.
When I start my computer, all screens stay black. The main screen is flickering on and off.
I do have to unplug the MST-hub several times but I didn’t figure out a routine.
Sometimes just the power supply, sometimes just the DP-connection, sometimes both of it.
It does actually work, but just after I unplugged it everytime.
Is it broken?
For your information:
I am on a GTX780, all screens are connected via DP-cables. No adapters are used. Power supply comes from micro USB power supply – no adapter as well.
Thanks for your help, and a quick response is appreciated because then I could simply send it back to the vendor.
Kind regards
Save Cancel
3 0 on 11-03-2021
Baak
Hi Muezli,
At what resolution you have a the 3 screen setup? Remember that the max is 1080P60Hz is max on that setup.
Have you tried plugging in the power straight into the PC instead of a Power supply?
Save Cancel
0
muezli
Hello Baak,
thanks for your response.
In fact I am using 2xUHD and 1xFHD.
I will try to switch to 3x FHD and post my results.
Nevertheless:
I don‘t get it why it doesn‘t work at startup but after replugging.
I would get it, if it just works bad. But it does not work at all until I replug it several times.
Btw, I had a look at the little guide which was with the hub. It tells that you can use 2xWQHD and 1x FHD.
0
muezli
So I tried it with 3xFHD and plugging the power into the computer.
Unfortunately it is the same result.
Even has it worked and I just restarted the computer, it didn’t work until I replugged the power.
I guess it doesn’t work properly and I have to send it back to the vendor. :/
0
Baak
I doubt it is a faulty unit. Could be, but I doubt it :).
Just checking, you don’t have any other display connected to your GFX right? Like a fourth?
Have you tried a full clean drivers install of the GFX? Using DDU to unistall all drivers is what I advice. And look for the best possible drivers to use with the GTX780. I don’t think the most recent are very good for this card. But I don’t know for sure.
Reply Cancel
0 0 on 13-03-2021
muezli
Well, I surrendered on this one and bought a StarTech-device.
..and what shall I tell you – it works just perfectly without any hickups.
Nevertheless, thank you very much for your efforts!
Save Cancel
Reply Cancel
Login to Reply
Reply Cancel
  • All Posts
  • Following Posts
  • Blog
Copyright 2025 Club 3D B.V.
