Hello,
I would like to know if this adapter: http://www.club-3d.com/index.php/products/reader.en/product/displayport-to-active-dvi-dual-link-cable.html provides 144Hz on FHD resolution or should i buy 330Mhz version.
Best Regards
Hello,
Best Regards
Hi cedr1k,
Yes you will need to get the 330Mhz version (CAC-1051), because it suppports higher specs and because the 270mhz version (CAC-1050) is no longer offered by us.
Officially the 1600p at 144Hz is not supported byt he specs but i know from feedback from end-users that it does work. You will need a good quality DVI Cable of course …
